Bug found? LTAP + ROS 7.8 + GPS issue
I’m afraid ROS 7.8 broke my GPS. I have an LTAP LTE which worked on ROS 6.x. This was going very well, until this weekend I decided to upgrade to ROS 7.8.
Since then my script no longer sends coordinates to my server. Nor do I get to see the GPS coordinates in Winbox.
Apart from the update, nothing has changed on the device. The GPS antenna is an external magnet antenna that has always worked fine and should definitely get a GPS lock at the moment.
Can someone please help me with this issue?
[admin@ON3KDR/M] /system/console> /port/print
Columns: NAME, CHANNELS, USED BY, BAUD RATE
NAME CHANNELS USED BY BAUD RATE
0 serial0 1 GPS auto
1 gps 1 115200
2 usb3 1 9600
[admin@ON3KDR/M] /system/gps> export
Apr/21/2023 00:59:42 by RouterOS 7.8
software id = FFGV-E8L3
model = RBLtAP-2HnD
serial number = D7290C74C2DD
/systemgps
set coordinate-format=dd enabled=yes gps-antenna-select=external port=serial0
[admin@ON3KDR/M] /system/gps> print
enabled: yes
port: serial0
channels: 0
init string:
set-system-time: no
coordinate format: dd
gps-antenna-select: external
[admin@ON3KDR/M] /system/gps> monitor
date-and-time: Apr/20/2023 22:42:06
latitude: none
longitude: none
altitude: none
speed: none
destination-bearing: none
true-bearing: none
magnetic-bearing: none
valid: no
satellites: 0
fix quality: 0
data age: never
