Bug? How can I create an empty associative array, then fill it to map strings to strings?
I’m trying to create an empty associative array that maps strings to strings, then add a few associations. It fails on all methods I tried.
Which of the issues below are bugs and how can I report them?
The associations I want to have to do are related to escaping strings so non-printable characters are HEX-encoded:
"\00"->"\\00"
"\01"->"\\01"
"\1F"->"\\1F"
"\7F"->"\\7F"
"\FF"->"\\FF"
I don’t want printable characters in the association.
Below is what fails and how. I’ve included a /system script environment remove 0 (on a system without any global variables set) in-between all examples.
Fails because the initial value isn’t parsed correctly (and has a trailing double-quote so \00 isn’t associated):
:global convert {"\00"="\\00"}
:set ($convert->"\7F") "\\7F"
:set ($convert->"\81") "\\81"
:put [/system script environment print]
 # NAME               VALUE
 0 convert            \81=\81;\00"=\00;\7F=\7F
:put [:typeof $convert]
array
:put "$convert"
?=\81;"=\00;=\7F
:put ($convert->"\00")
:put ($convert->"\81")
\81
:put ($convert->"f")
Fails because the initial value isn’t parsed correctly (and has a trailing double-quote so \81 isn’t associated):
:global convert {"\81"="\\81"}
:set ($convert->"\00") "\\00"
 # NAME               VALUE
 0 convert            \81"=\81;\00=\00;\7F=\7F
array
:put "$convert"
?"=\81;=\00;=\7F
\00
Fails because $convert becomes a nothing to which you cannot add association values:
:global convert value=
 # NAME               VALUE
 0 convert
nothing
:put "$convert"
Fails because the initial value isn’t parsed correctly (and has a trailing double-quote so \01 isn’t associated):
:global convert {"\01"="\\01"}
 # NAME               VALUE
 0 convert            \81=\81;\01"=\01;\7F=\7F
array
:put "$convert"
?=\81;"=\01;=\7F
\81
Fails because $convert cannot be declared with an empty association:
:global convert {}
syntax error (line 1 column 19)
 # NAME               VALUE
:put "$convert"
Fails because only the first association is stored as such; the rest of the array values are boolean results of string comparisons:
:global convert {"o"="o","f"="f","b"="a"}
 # NAME               VALUE
 0 convert            o=o;true;false
array
:put "$convert"
o=o;true;false
Sort of works because I initialised with an association that will never be used, but I cannot remove that association so technically this fails too:
:global convert {"##"=""}
 # NAME               VALUE
 0 convert            \81=\81;\00=\00;##=;\7F=\7F
array
:put "$convert"
?=\81;=\00;##=;=\7F
\00
\81
–jeroen
You can create an empty array by surrounding the “{}” with “()”, i.e.
:global convert ({});
The syntax error seems is a left over because of what MikroTik might’ve intended to allow at one point (creating functions, without requiring the “do” argument) vs. what actually ended up happening (“do” is required always, precisely because arrays can end up in “value”, and there’s no way to tell which is which).
You can report bugs to support at support@mikrotik.com, although I can tell you from personal experience you shouldn’t expect scripting bugs to be resolved quickly (as in next release or the next one after that), but they will be noted, so that shouldn’t discourage you from reporting them.
Thanks.
Which of the above do you regard as bugs?
–jeroen
I’d say everything, except the
part.
The default value for variables is indeed “nothing”, and the fact you can’t append to “nothing” makes sense in every way.
Also, while the
part is a bug, the fact you can easily work around it would make me think of it as a very low priority if I was in MikroTik’s shoes.
Thanks. I will report them in due time.
–jeroen
