Router OS v 7.11.2
LTE6 version: R11e-LTE6_V036
Failure to connect to Winbox after disable then enable firewall in Quick Set, can be reproduced by:
- Reset LHG to defaults
- Connect to Winbox OK
- No WAN IP at this stage (0.0.0.0)
- Disable Firewall in Quick Set
- Enable firewall
- Restart Winbox
- Fail to connect, also no neighbour discovery
I’ve noted the FW rules are not re-created equally between the initial default rules and when the FW button is disabled then re-enabled. Not a FW rule guru by any imagination, but suspect due to the significant differences something is causing the issue.
TBH quite frustrating as a newcomer, but finally tracked it down.
FW rules from default config:
# 2023-11-03 17:04:57 by RouterOS 7.11.2
# software id =
# model = RBLHGR
# serial number =
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
And these after the FW feature is disabled, then re-enabled from Quick set:
# 2023-11-03 17:10:29 by RouterOS 7.11.2
# software id =
# model = RBLHGR
# serial number =
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface-list=!LAN
Cheers
Lea
