Bug in 3.23
I have a scheduler event that runs at midnight that’s always worked on previous versions, but it will not create the file since upgrade to 3.23.
/queue simple print stats file stats
It works fine from the command line. I’ve tried executing a script instead, that contains the line, and it will not create the file either.
Any ideas?
Though I don’t think it’s your problem, you should have the equal sign:
/queue simple print stats file=stats
You said you tried putting that in a script and then executing the script from the scheduler and it didn’t work. Did you try running the script manually and did it work? I haven’t had problems with the scheduler in 3.23 myself.
Sorry for the confusion. The scheduler executes , but the file does not show under files.
I created a script which also shows to execute, but the file does not show under files.
If I run the line from command line, the file appears under files.
I don’t think the problem is with the scheduler, I think it’s with the command itself:
Ver 3.23 doesn’t seem to want to create the file stats.txt while running except from the command line.
Again, it works fine in the background in older versions.
A script with the command above works on my 3.23 router. Try creating a new script from scratch?
The problem was with policy.
I created from command line, and it added this and it created file okay:
policy=ftp,reboot,read,write,policy,test,winbox,password,sniff
I created scheduler event from the command line and it add this and didn’t create file:
policy=read,write,test
I changed the scheduler policy to the one created in script, and the command creates the file just fine!
yes, you need ‘ftp’ policy to work with files
