Bug in dhcpv6 pd pool
I’m having difficulty with the dhcpv6 pd pool.
I configured a / 48 pool with Prefix Length in / 56 (I also did with / 64).
I configured the pppoe server correctly.
Everything works normally when the first user authenticates on pppoe. The dhcpv6 pd pool assigns the first / 56 block.
When next user authenticates in pppoe or dhcpv6 pd pool assigns the same prefix already assigned to the first user. (Preventing the first non-access pppoe user).
Conclude that the dhcpv6 pd pool is not breaking the / 48 block on / 56 or / 64.
I would like to know if it is Mikrotik failure or configuration error.
I used version 6.39.1
thank you
