Bug in export from terminal? 7.20.1 and 7.20.2 CCR TILE
When I try to export from terminal, the export file (.rsc) does not show in “Files”.
obraz
obraz
CCR 1009-8G-1S-1S+ (tile)
7.20.1 and 7.20.2
If you are referring to Winbox “Files“ section then try to access it again (close/open Files window), I noticed also that sometimes new files doesn’t appear when Files window is opened, but appears when Files window is reopened. It seems that from recent ROS versions Winbox has refresh issues in Files section. This I noticed in WInbox v3, not sure for v4.
Yes, reopening the window “Files” in winbox 3.43 causes the file to appear.
Thanks for the tip.
