Bug in Export
We’ve been having issues for a while during the import of an exported config. It seems that the system-scheduler is being generated prior to the system-scripts, and if the scheduler is calling a script, the import will fail. We’ve been manually re-arraning but it used to work. It’s been a while since we’ve used it so not sure if it was in the 6.4 era or even earlier around v5 where this may have changed.
Thanks,
Carlos.
please try to use 6.21.1 where i could not reproduce this problem
Also, you can use verbose=yes when importing script to see the actual output where might be the problem.
I don’t like to complain, but why the heck such useful option for script import is not documented in Wiki??? :frowning:
Regards,
