karo84
August 15, 2009, 3:32am
1
HI!
/ip firewall filter print chain=forward
0 chain=forward action=accept src-address=23.3.3.10
then
/ ip firewall filter remove [/ip firewall filter find src-address=23.3.3.10]
or
/ ip firewall filter remove [find src-address=23.3.3.10]
What is going on?
I am using ROS 3.28
MT TEAM You have to fix this.
via winbox everything is ok, but via console you can add but NOT remove a firewall rule
I need to remove.
Regards Karapet
fewi
August 15, 2009, 3:44am
2
You need to quote src-address, as it’s a string.
Use
/ip firewall filter remove [/ip firewall filter find src-address="23.3.3.10"]
and it will work. It’s not a bug, it’s expected behavior.
HTH,
Felix
karo84
August 15, 2009, 8:19am
3
Ia have tried. No difference.
davidw
August 15, 2009, 1:38pm
4
Yep tested on v3.28 and can confirm the same behaviour
/ip firewall filter add chain=forward action=accept src-address=23.3.3.10
then
Does not work
I did get the following to remove it from the console
/ip firewall filter remove 5
not much use if you can’t work out the number to remove though
fewi
August 15, 2009, 4:10pm
5
Works for me on 3.28:
[admin@MikroTik] > /ip firewall filter add action=accept src-address=23.3.3.10 chain=output
[admin@MikroTik] > /ip firewall filter pri where src-address=23.3.3.10
[admin@MikroTik] > /ip firewall filter pri where src-address="23.3.3.10"
1 chain=output action=accept src-address=23.3.3.10
[admin@MikroTik] > /ip firewall filter remove [/ip firewall filter find src-address=23.3.3.10]
[admin@MikroTik] > /ip firewall filter remove [/ip firewall filter find src-address="23.3.3.10"]
[admin@MikroTik] > /sys pack pri
Flags: X - disabled
# NAME VERSION SCHEDULED
0 system 3.28
1 dhcp 3.28
2 routerboard 3.28
3 ntp 3.28
4 hotspot 3.28
5 security 3.28
6 advanced-tools 3.28
[admin@MikroTik] >
