I’ve noticed that when I run script from terminal or schedulle and call a global variable from another script (e.g. if RoS is running on routerboard or not - :global routerboard [/system routerboard get routerboard]) i can get the value either true or false. But if I run a script from netwatch it ignores a global variable and I need to redefine it again. Otherwise the value is NULL.
Is this a bug?
in subscript:
:global routerboard;
I need to define :global routerboard [/system routerboard get routerboard] also in subscript otherwise its not getting the vaule. So it’s no difference if I just use local varibale.
