Bug in v6.44.3
Hi all,
I used to use ssh connection to many Mikrotik devices, and then make a ssh tunneling to access internal resources, like SQL servers, Terminal servers, etc. It is nice for temporally connections behind remote router/firewall. Actually I have a few routers, updated to v6.44.3. I successfully connect to them via ssh client Putty. I make the ssh tunneling settings in Putty, for example - local port 4000 to be forwarded to remote internal address 192.168.0.100:3389, and than i run remote desktop client and connect to localhost:4000, actually connecting to remote internal address 192.168.0.100:3389,
but when I try to connect to internal server connection drops and Putty says “Fatal error. Strange packet received: type 82”.
I try with other ssh client, which support tunnels and it works with version of ROS 6.44.0, when I upgrade ROS to current - 6.44.3 - no more tunnels.
Best wishes!
The solution: /ip ssh set forwarding-enabled=both
Thanks to mikrotik support.
