Hi guys,
I think I have found a bug. Basically I telnet into a RB133 and run the following:
/interface wireless scan wlan1
this reports the number of available access points (SSID, Sig strength, Freq etc).
The above works fine and is very handy.
The problem is that if one of the Access points drops of the air (ie is powered off), the scanning process still continues to show it!
Is this a bug? The only way to rescan is to stop and then re-start the scan.
Any suggestions?
Cheers,
James
