Bug in wireless-test package - MT please correct.
I think I found a bug in the wireless-test package v.3.22 and 3.23 on several boards. (533x, 433, 133, 333)
The bug is a different reading/setting in winbox compared to the console/terminal.
If you change the value of “Hw. Fragmentation Threshold” in winbox ´interface / Advanced´ then you actually change the ´Hw.Protection Threshold¨.
Vice versa works the same. Set in terminal the ´Hw.Protection Threshold´ to a value and you see the “Hw. Fragmentation Threshold” in winbox set to that new value.
The actual “Hw.Fragmentation Threshold” can actually not set in winbox. It can in a terminal session. It would be nice to have this in winbox too. So its easy to know there are two different settings. Specially if you are new to the subject and tired after many hours reading!
Can the bug be confirmed and enlisted for in the next ROS upgrade please?
Rudy
I can confirm the bug, RB433 with wireless-test 3.23
