Bug? IP routing in ROS 6.5?
With ROS 6.5..
main gw CCRx36 4xSFP
wan: several ips 10.0.0.x
lan:
192.168.3.254/16
172.17.1.9/30
172.17.1.49/30
several routers connected via eth - bridged…
RO1:
ip:172.17.1.10/30
gw:172.17.1.9
RO2:
ip:172.17.1.50/30
gw:172.17.1.49
vary routers
ip:192.168.x.x
gw:192.168.3.254
from these routers:
ping to 172.17.1.10 or 172.17.1.50 ok
same as ping v to 192.168.x.x routers..
but if i want to ping 172.17.1.10 from 172.17.1.50 timeout happen…
same as ping from 172.17.1.50 to 172.17.1.10
with ROS 5.25 there no timeout…
only with ROS 6.x?
Fasth Path - unchecked..
HW Fast Path - unchecked
use IP Firewall - in bridge checked…
