I’m having some LTE issues with my new Chateau 5G R17 ax (modem RG650E-EU). I have great reception, but I’m getting terribly slow speeds (<100kbps) unless I start a WinBox torch session on the LTE interface.
I’m running routeros and wifi-qcom version 7.21rc4from Dec/29/2025 13:47:22. My LTE/5G modem is on the latest firmware.
Without torch running
[admin@MikroTik] > /interface/lte/monitor lte1 once
status: running
manufacturer: Quectel
model: RG650E-EU
revision: RG650EEU00AAR01A04G8G
current-operator: [REDACTED]
current-cellid: [REDACTED]
enb-id: [REDACTED]
sector-id: [REDACTED]
phy-cellid: [REDACTED]
data-class: LTE
session-uptime: 7m48s
imei: [REDACTED]
imsi: [REDACTED]
iccid: [REDACTED]
primary-band: B7@20Mhz earfcn: [REDACTED]
ca-band: B1@20Mhz earfcn: [REDACTED]
B20@10Mhz earfcn: [REDACTED]
ul-ca-band: B7@20Mhz earfcn: [REDACTED]
dl-modulation: qpsk
cqi: 13
ri: 2
mcs: 0
With torch running
status: running
model: RG650E-EU
enb-id: [REDACTED]
data-class: LTE
session-uptime: 1m12s
imei: [REDACTED]
imsi: [REDACTED]
iccid: [REDACTED]
primary-band: B1@20Mhz earfcn: [REDACTED]
dl-modulation: 64qam
cqi: 12
ri: 2
mcs: 11
rssi: -64dBm
rsrp: -92dBm
rsrq: -9dB
sinr: 19dB
Debug logs
2026-01-06 19:13:08 system,info device changed by winbox-3.43/tcp-msg(winbox):admin@192.168.88.254 (/interface set lte1 disabled=no mtu=1500 name=lte1; /interfac
e lte set [ find ] allow-roaming=yes apn-profiles=[REDACTED] band="" disabled=no mtu=1500 name=lte1 network-mode=lte,5g nr-band=""; /queue interface set lte1)
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> WDS - STOP_NETWORK_IFACE
2026-01-06 19:13:08 lte,error lte1 qmi: dropped reply
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> WDS - [notify] PKT_SRVC_STATUS
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> DMS - SET_OPERATING_MODE
2026-01-06 19:13:08 lte,debug lte1 qmi: state: radio off => idle
2026-01-06 19:13:08 lte,debug lte1 qmi: <<< UIM - ATTR_REQ
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> WDS - [notify] LTE_ATTACH_PARAMS
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> DSD - [notify] SYSTEM_STATUS
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> UIM - ATTR_REQ
2026-01-06 19:13:08 lte,debug lte1 qmi: <<< UIM - SLOTS_STATUS
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> NAS - [notify] SERVING_SYSTEM
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> NAS - [notify] SYS_INFO_IND
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> UIM - SLOTS_STATUS
2026-01-06 19:13:08 lte,debug lte1 qmi: slot #0 state: empty
2026-01-06 19:13:08 lte,debug lte1 qmi: slot #1 state: esim without profile
2026-01-06 19:13:08 lte,debug lte1 qmi: <<< UIM - GET_CARD_STATUS
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> UIM - GET_CARD_STATUS
2026-01-06 19:13:08 lte,debug lte1 qmi: UIM state: 1 APP state: 7, type: 2
2026-01-06 19:13:08 lte,debug lte1 qmi: <<< UIM - READ_TRANSPARENT
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> UIM - READ_TRANSPARENT
2026-01-06 19:13:08 lte,debug lte1 qmi: state: idle => SIM ready
2026-01-06 19:13:08 lte,debug lte1 qmi: <<< WDA - SET_DATA_FORMAT
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> WDA - SET_DATA_FORMAT
2026-01-06 19:13:08 lte,debug lte1 qmi: <<< WDA - SET_LOOPBACK_STATE
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> WDA - SET_LOOPBACK_STATE
2026-01-06 19:13:08 lte,debug lte1 qmi: <<< WDS - MODIFY_PROFILE_SETTINGS
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> WDS - MODIFY_PROFILE_SETTINGS
2026-01-06 19:13:08 lte,debug lte1 qmi: <<< WDS - SET_LTE_ATTACH_PDN_LIST
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> WDS - SET_LTE_ATTACH_PDN_LIST
2026-01-06 19:13:08 lte,debug lte1 qmi: set system preference, operator: [auto]
2026-01-06 19:13:08 lte,debug lte1 qmi: <<< NAS - SET_SYSTEM_SELECTION_PREF
2026-01-06 19:13:08 lte,debug lte1 qmi: >>> NAS - SET_SYSTEM_SELECTION_PREF
2026-01-06 19:13:08 lte,debug lte1 qmi: set radio state: online
2026-01-06 19:13:08 lte,debug lte1 qmi: <<< DMS - SET_OPERATING_MODE
2026-01-06 19:13:08 lte,debug lte1 qmi: state: SIM ready => online
2026-01-06 19:13:13 system,info,account user admin logged in from 192.168.88.254 via winbox
2026-01-06 19:13:19 lte,debug lte1 qmi: >>> NAS - [notify] SERVING_SYSTEM
2026-01-06 19:13:19 lte,debug lte1 qmi: state: online => searching
2026-01-06 19:13:19 lte,debug lte1 qmi: >>> NAS - [notify] SYS_INFO_IND
2026-01-06 19:13:19 lte,debug lte1 qmi: state: searching => deregistered
2026-01-06 19:13:19 lte,debug lte1 qmi: >>> DSD - [notify] SYSTEM_STATUS
2026-01-06 19:13:20 lte,debug lte1 qmi: >>> NAS - [notify] SERVING_SYSTEM
2026-01-06 19:13:20 lte,debug lte1 qmi: state: deregistered => registered
2026-01-06 19:13:20 lte,debug lte1 qmi: state: registered => packet service attached
2026-01-06 19:13:20 lte,debug lte1 qmi: state: packet service attached => connecting
2026-01-06 19:13:20 lte,debug lte1 qmi: >>> NAS - [notify] SYS_INFO_IND
2026-01-06 19:13:20 lte,debug lte1 qmi: >>> NAS - [notify] CURRENT_PLMN_NAME
2026-01-06 19:13:20 lte,debug lte1 qmi: >>> DSD - [notify] SYSTEM_STATUS
2026-01-06 19:13:20 lte,debug lte1 qmi: >>> WDS - [notify] LTE_ATTACH_PARAMS
2026-01-06 19:13:20 lte,debug lte1 qmi: >>> NAS - [notify] OPERATOR_NAME_DATA
2026-01-06 19:13:21 lte,debug lte1 qmi: >>> DSD - [notify] SYSTEM_STATUS
2026-01-06 19:13:21 lte,debug lte1 qmi: >>> NAS - [notify] SERVING_SYSTEM
2026-01-06 19:13:21 lte,debug lte1 qmi: >>> NAS - [notify] SYS_INFO_IND
2026-01-06 19:13:21 lte,debug lte1 qmi: <<< WDS - START_NETWORK_IFACE
2026-01-06 19:13:21 lte,debug lte1 qmi: >>> WDS - START_NETWORK_IFACE
2026-01-06 19:13:21 lte,debug lte1 qmi: state: connecting => connected
2026-01-06 19:13:21 lte,debug lte1 qmi: state: connected => connecting
2026-01-06 19:13:21 lte,debug lte1 qmi: >>> WDS - [notify] PKT_SRVC_STATUS
2026-01-06 19:13:22 lte,debug lte1 qmi: <<< WDS - GET_RUNTIME_SETTINGS
2026-01-06 19:13:22 lte,debug lte1 qmi: >>> WDS - GET_RUNTIME_SETTINGS
2026-01-06 19:13:22 lte,info lte1 IPv4: 10.16.47.128, DNS: [REDACTED], MTU: 1500
2026-01-06 19:13:22 lte,debug lte1 qmi: current apn: [REDACTED]
2026-01-06 19:13:22 lte,debug lte1 qmi: state: connecting => connected
2026-01-06 19:13:22 lte,debug lte1 qmi: state: connected => running
2026-01-06 19:13:22 interface,info lte1 link up
2026-01-06 19:23:03 system,info,account user admin logged in from 192.168.88.254 via winbox
I’m super happy about my unit except for this issue. Mikrotik is a great company and you folks make great sustainable products for a fair price. Thank you.
