BUG on 6.39.2
Hello all, i’m problabli fina a bug on this version, the command “ip ipsec peer find” doesn’t always return nothing.
Someone else are experiencing the same problem ? anyone knows some workarround ?
That’s not a bug. The find command (in any menu) is meant to be used in scripts only, and never returns/prints anything human-readable. More info here. For getting list of your configured ipsec peers you may want to try print or export commands instead.
