Hello
I got the same problem, vlan-header not supported. My OS is 5.11 i tried to downgrade to 5.09 problem persist. If I set switches port to disabled they got vlan-id 2 ? I tried and vlan id 2 is working, but only id=2 !!! Anyone else not, for separate vlan’s of course. I can see that your post is very old, some workaround ?
I suggest you too take a look at the resource, did you got sector wrrites count empty ? I got ! Just 0.00
I got another microtik router 750G that works fine, vlan and resources.
I think too it is some king of bug.
Greetings
Mike
problem still exist, my current workaround is to use ports 11-13 for vlan (ports with no switch cpu).
But the ports on the Atheros switch cpu aren’t usable with “software” vlan for me.
I got the same cpu Atheros8327 on my Rb1100AH,
You probably using trunk and switch with vlan’s.
I want to use embedded switch of this router to set the IP’s over to 7 clients, I need to use L2 switch, and want to seperate this using vlan’s.
Ha the best ! Only vlan tag 2, works, I checked it with various configuration. The rest vid are doing nothing ;(
Did you look at your router’s resources ? Yours didnt show the cycle writes too ?
I will send an email to support with it, very very strange behaviour, be more specific vlan’s don’t stick packets or stick it forever. Maybe if vlan-header works, but for me router’s says not supported ;(
Tell me you tried to build a trunk or try to separate phisycs port on router ? Using switch on router of course ?
