Bug Report - /system upgrade
Hi to every body…
I have found something that if im not wrong, it’s a bug. (correct me if i’m wrong)
I whant to create a script to auto-update my external antennas (that have no internet connection), so i’m trying to do it using the “/system upgrade” function of routerOS.
My antennas has only 3 packages installed, “system, ntp and wireless”. Is in this last package where i’m having problems.
When i do a “refresh” of available packages, I can see all packages, but the “wireless” one, is recognized as “wireless@”, so when i try to do a download-all command, only the “ntp” and “system” packages are scheduled and downloaded, ignoring the “wireless” one.
I have proved several versions of RouterOS from 6.37.1 to 6.38.3 trying to update to 6.38.5 and with all of them I get the same problem
Any idea?
Thanks a lot
