Bug? Reversed IP Addresses in Terminal setup
When I run “setup” from terminal, and go to add ip address or gateway, etc, it shows the current address reversed… so if you just push enter it breaks your config.
For example, if the current gateway or ip address is 192.168.0.1, it shows it as 1.0.168.192… forcing you to retype it correctly.
This is version 3.24 on RB411
yes, thank you for the report. It displays incorrect configuration, but at least it takes correct IP address from /ip address /ip route configuration.
We will fix the problem with reverse IP address/route in the upcoming version.
