(BUG) ROS v3.25 Cannot login to Winbox with IP
Suddenly I could not login with Winbox using IP, but…I can login using MAC Address.
Is this only happen to me or happen to others too ?
My machine:
/system resource> pr
uptime: 1d3h36m30s
version: “3.25”
free-memory: 1665596kB
total-memory: 1945840kB
cpu: “Intel(R)”
cpu-count: 2
cpu-frequency: 2992MHz
cpu-load: 32
free-hdd-space: 908120kB
total-hdd-space: 987124kB
write-sect-since-reboot: 2536912
write-sect-total: 2536912
architecture-name: “x86”
board-name: “x86”
check the ip adress print and ip route print output.
Also check the file menu maybe you have some autosuout.rif file generated, if yes then please send that to support@mikrotik.com
/ip addr pr and /ip route pr seems normal. And also I “can” telnet into it using IP.
Seems just port 8291 closed, but…I checked it already open.
Anyway, my router generated autosupout.rif automatically & it sent to my email automatically. I will forward to support team.
Have you figured out what was the problem?
I’m using ROS4.2 and can login to MAC address just fine. When I try to ssh or winbox to the IP address my authentication is refused (wrong user name or password)…
EDIT: my problem was an incorrect access mask for the particular login account.
