BUG: RouterOS v4.6 on RB750 drops frames with certain MAC
Recently has installed the RouterOS v4.6 on my RB750. After reboot I noticed, that one of my computers is unable to connect to RB750 (neither with winbox, nor with telnet, pinging doesn’t work too - the MAC-address of RB750 doesn’t resolve with ARP). After doing some experiments I stated, that any computer having 00, 01, 02, 03 or 04 in the 2nd octet of its MAC-address (00:13:76:28:00:06, for example) is affected. Changing this address to 00:13:76:28:05:06 makes it work. Writing the 00:13:76:28:00:06 address to another machine leads to similar connection loss. Changing any other nibble wasn’t helpful. No MAC-filtering was made - the device is just reset to default configuration.
This was observed on RB750 with RouterOS 4.6 only - downgrading to 4.5 solves the problem. Another boards (RB600, RB411, RB433) wasn’t known to produce such a bug.
Yes, we have some problem here. Looks like this problem only happen on RB750s, I haven’t seen any other board have this issue.
Wrote to MikroTik’s support. They couldn’t reproduce it, and asked for additional information
Have the same problem with v4.6 on RB750. RB just keeps sending who-was arp.
tcpdump snapshot:
listening on eth0, link-type EN10MB (Ethernet), capture size 96 bytes
22:14:37.360570 00:0c:42:56:26:62 > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 60: ethertype ARP, arp who-has y.y.y.y tell x.x.x.x
22:14:37.361304 00:00:5e:00:01:02 > 00:0c:42:56:26:62, ethertype 802.1Q (0x8100), length 64: ethertype ARP, arp reply y.y.y.y is-at 00:00:5e:00:01:02
22:14:38.360575 00:0c:42:56:26:62 > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 60: ethertype ARP, arp who-has y.y.y.y tell x.x.x.x
22:14:38.368668 00:00:5e:00:01:02 > 00:0c:42:56:26:62, ethertype 802.1Q (0x8100), length 64: ethertype ARP, arp reply y.y.y.y is-at 00:00:5e:00:01:02
22:14:39.360612 00:0c:42:56:26:62 > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 60: ethertype ARP, arp who-has y.y.y.y tell x.x.x.x
22:14:39.361771 00:00:5e:00:01:02 > 00:0c:42:56:26:62, ethertype 802.1Q (0x8100), length 64: ethertype ARP, arp reply y.y.y.y is-at 00:00:5e:00:01:02
22:14:40.390802 00:0c:42:56:26:62 > ff:ff:ff:ff:ff:ff, ethertype 802.1Q (0x8100), length 60: ethertype ARP, arp who-has y.y.y.y tell x.x.x.x
22:14:40.391999 00:00:5e:00:01:02 > 00:0c:42:56:26:62, ethertype 802.1Q (0x8100), length 64: ethertype ARP, arp reply y.y.y.y is-at 00:00:5e:00:01:02
You can workaround this problem by adding static arp
[admin@N3] > ip arp print where interface=vlan66
Flags: X - disabled, I - invalid, H - DHCP, D - dynamic
 #   ADDRESS         MAC-ADDRESS       INTERFACE
 6   y.y.y.y   00:00:5E:00:01:02 vlan66
It didn’t work for me - the affected computers still couldn’t neither ping, nor winbox/telnet that RB750
MikroTik support group finally reproduced this bug and promised to patch it in the next version of RouterOS
