There is a bug since version 7.19 that does not seem to be getting resolved.
Up to 7.18.2, the following scenario worked perfectly:
[DHCP Server + Bridge + EOIP_Source] <------------> [EOIP_Destination - Bridge_B - DHCP Client]
Up to version 7.18.2, Bridge_B would perfectly obtain an IP from the DHCP Server at the other end of the EOIP. In 7.19, there was a change in the DHCP, and now it is impossible for Bridge_B to obtain an IP.
Curiously, the EOIP_B interface does obtain an IP address, but the bridge_B to which the interface belongs does not, meaning that my machines at the other end can no longer function.
I have tried multiple hardware and RouterOS versions, and the result is always the same; it only works with 7.18.2.
Please, Mikrotik, can you fix this?
I can't upgrade from 7.18.2 in my production environment for this reason.
