i use routeros 3.2,and setup upnp,and it work fine!
but if i reboot routeros,then upnp don’t work.
What do you have in the ‘ip upnp export’ and ‘ip firewall nat print dynamic’ ?
[admin@routeros] > /ip firewall nat print dynamic
0 chain=srcnat action=src-nat to-addresses=81.161.73.48 to-ports=0-65535
src-address=192.168.0.0/24 out-interface=wan1 X chain=dstnat action=dst-nat to-addresses=192.168.0.33 to-ports=3389
dst-address=81.161.73.48 dst-port=3389 protocol=tcp
[admin@routeros] > ip upnp export/ip upnp
set allow-disable-external-interface=yes enabled=yes show-dummy-rule=yes
/ip upnp interfaces
add disabled=no interface=wan type=external
add disabled=no interface=lan type=internal
I have the same problem with Routeros 3.4 on RB532. UPNP service doesn’t work after rebooting the router. Disabling and enabling the service again in UPNP settings makes it work again.
upnp don’t work on 3.11
