[Bug] User manager unusable after power outage (or device unplug/replug)
On an hex POE if I unplug/replug (which simulate a power outage), user-manager is unusable. All commands to it do timeout :
/user-manager/monitor
action timed out - try again, if error continues contact MikroTik support and send
 a supout file (13)
We can plan a reboot or shutdown, but not a power outage. It seems like it is related to the sqlite db, because if I delete the files, user-manager makes new one and then works. But everything is lost. This need to be fixed.
But in the meantime, how can I recover from such an issue ?
I tried to fix the apparently corrupted sqlite db. Downloading um5.sqlite and um5.sqlite-wal, and then :
sqlite3 ./backup/um5.sqlite .dump | sqlite3 um5.sqlite
I then upload the new db, but user-manager is still not working (and nothing about it in logs)
i have the same problem but still can’t find how to fix this.
poor support from mt
