BUG: v6.32.2 - System reset-configuration no-defaults=yes / import
I think there is a bug in v6.32.2
If you export the config:
/export file=export.rsc
Then run the command:
/system reset-configuration no-defaults=yes run-after-reset=export.rsc
The import will fail on:
/ip ipsec mode-config
/ip ipsec policy group
As it is trying to import default values that already exist.
Apologies;
Using
/export file=export compact resolves the issue.
Please close thread.
you mean, “/export” and “/export compact” produce different results? that should be considered a bug
