There are several tunnels IPsec. Regardless of time and without changing any settings tunnels stop working.
In the settings you can see that the key exchange in one direction occurs, but the traffic flow is not (IP->IPsec->Installed SAs->some key->Current Bytes=0).
After several reboots tunnel restored. After spending some time again stops working. Fix please!
Remote office work impossible. Business idle incur losses
Well, this is by ‘design’ and not a bug. You should explicitly take precautions to keep the tunnel up. On Juniper and Cisco you need to do the same thing.
An IPSEC tunnel only stays up when there is traffic.
Yes, IPsec tunnel stays down if there is no traffic. But he must stays up if traffic starts. And sometimes it does not. That’s what I wrote in my problem.
