Hi all,
Hi mikrotik,
i discovered following Bug in WebFig:
If you select something else than “all” or “main” in the DropDown Menu on “IP=>Routes” the Routelist is empty.
Tested with RouterOS 6.4.Maybe someone can confirm this bug.
As it is just a GUI issue it is not critical but annoying.
