Bug: Winbox does not show BGP Confederation Peers
where is the best place to send bug reports?
I run a BGP confederation:
[dg8ngn@DB0INN] > routing bgp instance print
Flags: X - disabled
0 name=“default” as=65533 router-id=0.0.0.0 redistribute-connected=no
redistribute-static=no redistribute-rip=no redistribute-ospf=no
redistribute-other-bgp=no out-filter=“” confederation=64625
confederation-peers=65530-65535 client-to-client-reflection=no ignore-as-path-len=no
routing-table=“”
Unfortunately the Confederation Peers are not shown in Winbox → Routing → BGP → Instances → default: “Confederation Peers: ” :frowning:
OS: RouterOS 4.11 on RB433
Thank you
Jann
Email support@mikrotik.com for an official bug report.
I can confirm that. I have tested it with a couple of Routerboards within the RB4xx series (RB411AH, RB433AH, RB450G) and on all boards this bug apears. I used RouterOS 4.11. On an older Board RB532 the bug appears too. In the CLI-interface the confederation-peers are listed and the boards do certainly work within the confederation.
I have tested it now with RouterOS 4.11 on a Routerboard RB1100 (PPC) device. The bug in Winbox does NOT appear. Everything looks fine.
regards
Egbert Zimmermann
