Hi there.
After some time without using my Mikrotik hardware, I decided to use it again and make a frsh config.
I used “Whisky” app on my M2 mac to launch Winbox (basically a frontend to create and manage Wine bottles).
It worked perfectly without problem.
But yesterday, when I tried again with latest Winbox version I had a problem.
When I connect on my router or AP, I can open “direct” windows like “Bridge”, “Terminal”, “Files”, … It works.
But if I want to open sometinf in submenu (“IP > Adresses”, “System > RouterBOARD”, …) it doesn’t work at all, nothing appear.
I tried with a Brew install of Wine and even with the packaged Winbox app for mac, it’s always same problem.
When I try to run winbox with wine CLI (to check errors), there is no error in terminal.
If someone have a clue or workaround, I really appreciate it.
