bug?
Wireguard on AP does not show allowed IPs and if you add an allowed IP it doesn’t commit and instead blanks the line and thus tears down the session. Is this a known issue?
Not to me. And it would be good idea to mention RouterOS version.
Yes, please provide config. ( and what version of 7 ?)
/export file=anynameyouwish
v7.1 and current ios app. I’m not dropping a config file into the forums though.
suit yourself Gluck.
“bug?” nice title, describe yourself?
no sane person would export a config file and drop it in forums, that’s crazy talk.
posted from my phone, not sure why only that came through. 'mikrotik app bug?' was the intended title.
this is a mikrotik forum, is the same, is not sufficently descriptive,
is obvious that is about mikrotik…
One valid title?
For example:
“Wireguard on my APP does not show IPs & drop”
I would use the iphone to USE the wg tunnel, not so sure I would want to configure it using the IPHONE but if one is desperate…
But I can confirm that allowed IPs is indeed missing.
I suspect that the coding of the APP has not kept up with the latest changes as their focus is more on the RoS itself.
Otherwise I can login to a vers7 config via wireguard at least. ( input chain rule )
