Hello, we have working script to automatic ROS upgrade.
The script works well, but it upgrades to latest current version, that is not always stable enough.
There is new feature from v. 6.31, that enabled to choose channel of required upgrade type - Bugfix, Latest, Developer.
It can be done easily from WinBox, but it is not documented well yet.
So can you recommend us how to use upgrade channel in script?
It is good to know the setting is remaining.
Is it any chance to set the type of update by script. You know that edit hundreds of klient devices by hand is not very comfortable.
That is the reason we use scripting.
Miroslav
