After 1 month, i done a lot of tests and i want report a bug.
Reproduce:
Ping from wired PC to Mikrotik IP for some hours and you can see stable ping. After that, enable all graphs from web interface. You will se every 300 pings a small o big delay. If you disable all graphs, you will not have more delays again.
Hardware and software in:
- CCR1009-7G-1C-1S+: 6.44beta6 (small delays without lost connectivity)
64 bytes from 192.168.2.1: icmp_seq=2956 ttl=64 time=0.122 ms
64 bytes from 192.168.2.1: icmp_seq=2957 ttl=64 time=0.150 ms
64 bytes from 192.168.2.1: icmp_seq=2958 ttl=64 time=0.146 ms
64 bytes from 192.168.2.1: icmp_seq=2959 ttl=64 time=1835 ms
64 bytes from 192.168.2.1: icmp_seq=2961 ttl=64 time=0.121 ms
64 bytes from 192.168.2.1: icmp_seq=2962 ttl=64 time=0.112 ms
64 bytes from 192.168.2.1: icmp_seq=2964 ttl=64 time=0.122 ms
64 bytes from 192.168.2.1: icmp_seq=2963 ttl=64 time=1638 ms
64 bytes from 192.168.2.1: icmp_seq=2960 ttl=64 time=4639 ms
64 bytes from 192.168.2.1: icmp_seq=2965 ttl=64 time=0.157 ms
64 bytes from 192.168.2.1: icmp_seq=2966 ttl=64 time=0.154 ms
64 bytes from 192.168.2.1: icmp_seq=2967 ttl=64 time=0.152 ms
64 bytes from 192.168.2.1: icmp_seq=2968 ttl=64 time=0.160 ms
- CCR1009-7G-1C-PC: RouterOS v6.42.7 (stable) (big delays and sometimes lost connectivity for some seconds)
64 bytes from 192.168.6.1: icmp_seq=4147 ttl=64 time=0.246 ms
64 bytes from 192.168.6.1: icmp_seq=4148 ttl=64 time=0.201 ms
64 bytes from 192.168.6.1: icmp_seq=4149 ttl=64 time=0.259 ms
64 bytes from 192.168.6.1: icmp_seq=4150 ttl=64 time=0.204 ms
64 bytes from 192.168.6.1: icmp_seq=4151 ttl=64 time=1180.227 ms
64 bytes from 192.168.6.1: icmp_seq=4152 ttl=64 time=177.025 ms
64 bytes from 192.168.6.1: icmp_seq=4153 ttl=64 time=1237.177 ms
64 bytes from 192.168.6.1: icmp_seq=4154 ttl=64 time=237.276 ms
64 bytes from 192.168.6.1: icmp_seq=4155 ttl=64 time=1213.142 ms
64 bytes from 192.168.6.1: icmp_seq=4156 ttl=64 time=208.069 ms
64 bytes from 192.168.6.1: icmp_seq=4157 ttl=64 time=1267.998 ms
64 bytes from 192.168.6.1: icmp_seq=4158 ttl=64 time=264.042 ms
64 bytes from 192.168.6.1: icmp_seq=4159 ttl=64 time=1243.505 ms
64 bytes from 192.168.6.1: icmp_seq=4160 ttl=64 time=243.211 ms
64 bytes from 192.168.6.1: icmp_seq=4161 ttl=64 time=1302.080 ms
64 bytes from 192.168.6.1: icmp_seq=4162 ttl=64 time=301.576 ms
64 bytes from 192.168.6.1: icmp_seq=4163 ttl=64 time=1281.141 ms
64 bytes from 192.168.6.1: icmp_seq=4164 ttl=64 time=280.666 ms
64 bytes from 192.168.6.1: icmp_seq=4165 ttl=64 time=1258.254 ms
64 bytes from 192.168.6.1: icmp_seq=4166 ttl=64 time=253.938 ms
64 bytes from 192.168.6.1: icmp_seq=4167 ttl=64 time=1311.039 ms
64 bytes from 192.168.6.1: icmp_seq=4168 ttl=64 time=309.231 ms
64 bytes from 192.168.6.1: icmp_seq=4169 ttl=64 time=1368.947 ms
64 bytes from 192.168.6.1: icmp_seq=4170 ttl=64 time=368.966 ms
64 bytes from 192.168.6.1: icmp_seq=4171 ttl=64 time=0.167 ms
64 bytes from 192.168.6.1: icmp_seq=4172 ttl=64 time=0.168 ms
64 bytes from 192.168.6.1: icmp_seq=4173 ttl=64 time=0.207 ms
64 bytes from 192.168.6.1: icmp_seq=4174 ttl=64 time=0.193 ms
64 bytes from 192.168.6.1: icmp_seq=4175 ttl=64 time=0.178 ms
64 bytes from 192.168.6.1: icmp_seq=4176 ttl=64 time=0.189 ms
Both routers was tested using SFP GPON to connect to internet.
Do you have some information about this problem?
When you login in web interface, i also see delays when you click in different options.
Thanks.
