If you select a device then click the copy button the history graph will be reset and all the collected data will be gone.
Copying a probe includes XML for all the devices it is installed on.
If you click “add static” the dude crashes.
(multiple items probably all due to the same bug(s) or related somehow)
If you export a large configuration file probes will start failing and report as down.
Often labels will show Rx:[Interface.InBitRate] Tx:[Interface.OutBitRate] instead of the value. Reported when 3.6 was released?
False positives, devices that are not actually down have probes timeout.
Ping will usually record some value and continue to record that value for days. Manually Reprobing causes the value to reset. An example would be it is impossible for my server to have a ping of 50ms (it is connected on the local segment on a Gigabit network) but it does then if I manually click reprobe ping will drop to 1ms.
The remove resolved button on the outages tab of services doesn’t remove resolved outages.
You can remove resolved per map and per device but not from within in the global services panel.
Problem with Dude 4.0 Beta 2 STATIC to add object on the map.
The Dude see a mistake in closing the software.
I’m using Windows Vista Home Edition br / SP2.
Error:
This application has requested the Runtime to terminate it in an
unusual way.
Please contact the application's support team for more information.
Windows Problemans Information:
Assinatura do problema
Nome de Evento de Problema: APPCRASH
Nome do Aplicativo: dude.exe
Versão do Aplicativo: 0.0.0.0
Carimbo de Data/Hora do Aplicativo: 4c3ebdaf
Nome do Módulo de Falhas: dude.exe
Versão do Módulo de Falhas: 0.0.0.0
Carimbo de Data/Hora do Módulo de Falhas: 4c3ebdaf
Código de Exceção: 40000015
Deslocamento de Exceção: 001e7f80
Versão do sistema operacional: 6.0.6002.2.2.0.768.3
Identificação da Localidade: 1046
Informações Adicionais 1: eb0b
Informações Adicionais 2: 8f1d2176c8233e1928674e922c8af925
Informações Adicionais 3: cc6b
Informações Adicionais 4: cdefad7604980eec0af9d32bf4ce8b9a
Informações adicionais sobre o problema
ID de compartimento de memória: 1957603556
