Bugs in "MT_Syslog.exe" log not saved!
Dear MikroTik Support,
I would like to highlight a system logic bug in your “MT_Syslog.exe” a essential application which I used to capture the SysLog activity of the RouterBoard.
The bug is that… once the server system that is running the “MT_Syslog.exe” reboots or shutdown without first terminating or closing the “MT_Syslog.exe” application properly all the laters logs just gone missing and not saved into as a retrieveable log records for viewing later.
Could you help fix this bugs in “MT_Syslog.exe” as I used it primarily as a SysLog recorder in event of a system technical diagnostics audit from time to time?
Thanks.
Best Regards,
Rodney Yeo
MT_syslog.exe is discontinued for 7 years already! use another syslog program, there is plenty of them. google syslog.
example http://www.kiwisyslog.com/syslog-info.php
Thanks Normis… I have just tested the kiwisyslog but it seems quite cryptic to use.
I revert to 3CSyslog.zip and it work properly now… that is even I deliberate reboot the server with out closing the syslog application and it still retained the previous data captured into the syslog.log file properly.
http://support.3com.com/software/utilities_for_windows_32_bit.htm
This is the type of fool proof Freeware Syslog Daemon for Windows 95/98/NT which I have been looking with fail safe data retrival function.
Thanks again.
Rodney
For those interested in sending syslog data to SQL:
I have used syslog2ODBC
Works great for pumping syslog data to SQL / access etc.
Craig
That is great! What is the URL to download this file? Is it a freeware or paid ware version?
Thanks,
Rodney
Freeware..
Here is the link… http://sourceforge.net/projects/syslog2odbc/
Craig
Thanks a lot… I will test it out!
Best Regards,
Rodney
