It’s better to make topology according to local placement conditions. Use static wds links between the devices like wires and virtual APs for client’s connection. But remember. Run wires rather everywhere even if you think you can’t.
I have attached panoramic image in default of topology
I precise that distance between basebox 2 and QRT 2 is around 400 meters.
And when I move at place where QRT2 will be installed I receive low signal on smartphone.
I have changed the picture of Reza Moghadam according my situation (I hope that this can better express my idea ).
I choosed these hardwares because I possess them already. And I think that diagram design by Reza Moghadam can be adapt to any Mikrotik hardware.
Well. It depends if you really need to build it for free. Or if you choose to spend some money for proper devices and avoid future problems. Just some of them you should expect in your proposed case: low throughput, high latency, high packet loss and client devices without signal or with but without access to Internet. Just think about the consequences of using the same frequency for all communication between all devices including the clients at once. Especially when they are weak and moving like phones… I would build the star network on 5g between the places and use local 2g devices you already have as Ap. Just take it as opinion or advice before you start to prepair never ending story of solving signal quality or performance problems.
Using wds you will have to share the same frequency because you will use the same radio for everything. You cannot use one frequency for wds link and other for connecting the clients. This is the main restriction you cannot go over. Other problems will make the used antenna types of mentioned devices. But it is theoretically possible so if you have plenty of time for playing, let’s start to play. Just avoid the mesh and use static wds links.
AP1 (RB951G) should provide INTERNET. And his IP address is 10.5.50.3
Unfortunately when I connect a device it can’t give its IP address…however I have set up HOTSPOT…what wrong
AP2 (QRT2) is connecting with WDS without problem but “Error: no internet connection” when I try to update cloud.
