Wondering what to use to build a good AP/CPE combo for one of my test bed towns. I want to use the SR9 card. I was thinking about putting sr9 with a 532A and then using wrap boards for the CPE. Maybe just use a rubber duck antenna for customers within 1 mile, then they can just place is on their desk and hopefully get good signal. customers outside the 1 mile, I will use wrap board in the outdoor case and mount it to the outside of thier house. Any siggestions on hardware, and if this will work as good as I think it will? Thank you.
any input any 1?
I haven’t researched the AP as much as the client unit, but Rootenna has a good 900MHz unit on wisp-router.com.
with it, all you really need to worry about is POE and outdoor ethernet.
I haven’t found good AP antenna I like for 900MHz at this point, but the real money, the cost, is on the client AP. Rootenna seems to be the way to go.
he was talking about if indoor AP on 900mhz would be possible..like maybe by a window but in side a house or appartment, not out door.
anyone?
I wouldn’t count on an indoor rubber duckie going more than a few hundred yards - a mile is unrealistic in my opinion.
I have marginal signal at my desk with trango 900 11 db ap to a su with 10db patch at 0.25 miles both with 26dbm output and -98 receive sensitivity.
I’d scratch that idea ![]()
Scott
The Trango 900 is only rated at 400mw, the SR9 does 700mw.
