Hey Guy’s.
I thought that this setup would be a lot easier than what it turns out to be.
I basically have this:
Example-
Hard ware ~~ Internet Cloud - DSL Router with range of 5 IP’s - MT Public Int- MT Local Int
Subnets ~~~ #%$#%#$%^ - $$$.$$$.$$$.54/29 - $$$.$$$.$$$.54/29 - some local subnet
IP conf ~~~~ ------------- - IP $$$.$$$.$$$.55 - IP $$$.$$$.$$$.56 - some local IP
Now the internal network is working great (IP set up along with DHCP)…long story short.
I can do the DHCP on public and PPPoE on public…but How do I create the static route
and set up my DSL router as my gateway? Where do I set up a “Default route”?
I’ve tried IP > Routing > +route and then it doesn’t recognise which interface to use.
I also can not manually change this. I’ve also tried adding it via telnet / console.
I guess what I’m asking is if you have done this before and have a static routing how to,
could you share your knowledge? Please?
This is bringin me down
