Good day
hoping someone can assist I have use the mikrotik builtin pptp vpn client in the past to connect to another mitkrotik routers to create site to site vpn tunnels using pptp which worked well until recently when i tried to setup pptp connection using the builtin client. I enter my pptp credentials , remote wan ip for pptp server but the connection would registered to a unknown network. I can enter the wrong credentials and set a arbitraty ip address on the pptp on the client and it would stil registered to a unkown network and recieve a dhcp ip address in the 10.112.x.x network. I have tried the this on two MK unit RB915 and RB751 on version 6.43.4 and i get the same result has anyone come across this before is it a bug this happens for all builtin vpn clients its seems.
Any help would be highily appericated,
Below is example of dummy pptp client config which register to unkown ip address
admin@NavTVROOM] /interface pptp-client> print
0 R name=“SEAFOOD” max-mtu=1450 max-mru=1450 mrru=disabled connect-to=1.1.1.1
user=“kronos” password=“” profile=default keepalive-timeout=60
add-default-route=no dial-on-demand=yes allow=mschap1,mschap
10.64.65.54/32 10.112.113.102 SEAFOOD
