Bulk Upgrade of New Routerboard Hardware?
Is there any fast way to bulk update say 50 new Routerboard routers with the required RouterOS and Base configuration file?
I saw some information about using Netboot with Netinstall, but it looks like you still need to hold the reset button on every unit and most of the instructions did not elude to whether you could select multiple units from the list.
Shane
You can do mass update by dude. Not sure about the config file now.
