bungalow WiFi in mesh with seamless roaming....
hello,
i have a bungalow which has 3 floors (Drawing Attached)
i need to install a complete wifi solution for the entire place with seamless roaming but with a single SSID.
i plan to put Groove 2Ghz to use with sector antenna on the outside of the bungalow. planning on 3 units. all will be connected via Ethernet cables.
suggestion and input from you all will be very helpful.
-sid
