Bup file too big.
Friends.
I have an RB600 working fine since tree years ago.
When i make a back up file after new configurations, it results in 9.6Mb back up file.
I thin this is bad. Any idea??
Why is that bad? If you have a lot of configuration, backup file will be bigger. You can check what configuration you have, and remove something that you don’t need.
Thanks for your answer.
I have 40 DHCP clients - 10 Firewall rules - 9 NAT rules - 12 routes - 3 DHCP servers an i don´t see nathing more important.
Thas fine for this size?
I forgot to comment that it´s occur suddenly, with te same configuration that always it had with smaller size of backup size.
i made a factory reset, and is the same. The file always reach 9,6Mb
Regards.
