Hi all,
I have a Mikrotik RouterOS software (v2.9.42) installed on a PC equipped with an Asus P5PE-VM motherboard. Everithing is ok, it is working very well. However, trying to upgrade the software from the 2.9.42 to the 2.9.43 version, after the upgrade process was completed and the kernel successfully charged too, I incurred in a blocking “BUS ERROR” failure.
Any advice/help will be very very appreciated.
Giovanni
