Buying CHR Licence - No Luck
Hello to all,
I would like to buy an AWS CHR Licence in order to remove the 1Mbit Shaper,
Found and tried to follow the wiki regarding this. https://help.mikrotik.com/docs/display/ROS/Cloud+Hosted+Router%2C+CHR#CloudHostedRouter,CHR-Paidlicenses
I am guessing that my account on the forum is not considered a Mikrotik Account.
Tried to register but it says I am already registered.
Tried to log in to MT with my forum credentials (https://mikrotik.com/client/) but no luck.
Tried to reset the password but I never receive the recover your password email either.
Any ideas? Is this common?
I suggest you to contact Mikrotik support via e-mail at support@mikrotik.com
This forum is user forum, while MT staff do read (and answer) some threads, their feedback here is not guaranteed.
It means this email is used. Request a password with that same email.
Login - Email.
Forum login will not work .
Thank you very much for the quick reply.
Unfortunately, when i try to reset the password, i never get that email for the reset link.
Maybe, something has happened with my email in the database not sure.
Should I just send support an email about it?
Hey hey!
I saw normis reply again and it worked.
LOGIN = Email (not username)
Sorry for the inconvenience!
