Buying Mikrotik for Unifi hotel
hello everyone, I would like to ask you again to all the experts in the industry my draft Unifi access points in hotels. In this hotel there are 3 access points Unifi ac lite which are operated by Unifi Controller software, these access points transmit 2 SSID for a private password-protected WPA2 hotel managers and a clear signal for hotel guests, this SSID free as soon as the client connects Voucher Code prompted this far all is well. I want to give a different ip class Unifi Access Point System, by the time the office computer, printer etc. are connected with the same ip class: 192.168.1.xxx. and so I think you have to totally change the way we manage them. In hotel Eolo ISP connected to a router with 192.168.1.1 TPLINK PPOE configuration dhcp: 192.168.1.100 to 192.168.1.199 with a normal switch at cheap price. They have advised the Router Mikrotik Mikrotik or HEX RB750Gr3 RB960PGS to create VLAN feature firewall? I vvorei also make sure the Internet from customer sites. Thank you!
If the unifi has two ssid it more depends how the unifi is seperating the two ssid. It might be just putting both bridged onto the same lan port which would explain what your seeing. What you need to do is place each ssid on a vlan perhaps then on a mikrotik router you can route each vlan to a different dhcp server and network to keep both separate.
