BW test accross a routed network
Good Morning
I have been trying to get Bandwidth testing working across our network which has around 30 sites. The RB750UP are been used to power some links at each site. The radio links are on Vlans and the IP address of the RB750UP is on the management network which is routed to each site. If 2 x RB750 are on the one site that works. If we have a RB750 at a remote site bandwidth testing does not work. There is other gear in-between for routing only. There is no firewalls in place as of yet. Does the bandwidth testing feature only work on the same layer2 network or have I done something wrong?
Each MikroTik device has factory default settings with each port in a different bridge group and each one on a different vlan that is trunked out the first port.
