Bypass Hotspot
So I’ve managed to get a Hotspot setup, with logins, and it’s been working fine - but we’re now trying to get a Chromecast onto the network, but it doesn’t like the hotspot login.
I thought I’d set it up right to bypass, and with MAC Address logins, but it doesn’t seem to want to connect.
Thoughts?
Edited due to delay in screenshots being posted…
Haha, sorry about that, posted it before thinking I should probably add screenshots.
What was your original comment? I’m sure I’ve just missed something obvious but can’t see the forest for the trees.
Was going to suggest IP Bindings… that should take care of it. Are you sure of the MAC Address?
Yeah double checked that, off the Google Home app.
Was it connected before you setup the hotspot? Or if you disable the hotspot.
Nah it’s a new Chromecast.
Will try disabling the hotspot and let it connect when I get back to station.
Disabled the hotspot and it works fine - added a new bypass rule and it seems to be working once re-enabled.
Cheers!
