Dear all,
I have to test the load on my new Mikrotik CCR1016 router.
I have a running captive portal which currently authenticates via the local database.
I want to bypass local authentication in the Mikrotik such that clients can use any username/password and login via the Captive Portal.
If possible, I also want each user’s bandwidth to be limited to 512-512 kbps each.
If this possible? Any help and suggestions will be appreciated.
Best regards,
Tek
