Bypass Mikrotik Hostpot 1:1 Nat
Hi there,
I have a network with multiple ip ranges:
A: 192.168.1.0/24
B: 192.168.10.0/24
C: 192.168.20.0/24
A and C need to see Hotspot, Hotspot is on 192.168.20.1, so C can easily see gateway but for A, clients need 1:1 Nat to see the Hotspot gateway correctly. but B is stuck behind Hotspot gateway, i need to B clients bypass Hotspot to see each other, not to see the Wan.
now problem is, when router is connected, switches can not connect clients in B to each other correctly (if they have active connection, connection stays), when i disconnect router everyone can see eachother in B and other networks, as soon as i connect router again, idle clients hide behind Hotspot and can’t see each other any more.
