this is my first post in forum, I’am a newbie in Mikrotik routers but I want to learn.
I need a script to bypass a mobile phones connected to wifi network to different dhcp pool ( to get tem only to access internet ).
I want to have clean pool with company pc-s without mobilephones in same ip range.
I can’t change wifi ssid-s and put diferent for pc/mobile ) I now that this is te easiest solution),
Is it possible, with a script (my scripting is very bad) to check the DHCP Active Hostname for a string, say
"android* and assign it to a specific DHCP pool?
