Bypass ports
I have a simple scheme
MkroTik Ether11 <—> Gig 0/1 Switch Gig 0/2 <----> ISP
Using the following configuration
MikroTik RB1100AHx2
add address=192.168.1.1/30 interface=ether11
Switch
interface GigabitEthernet0/1 - 0/2
switchport access vlan 222
switchport mode access
BUT This address 192.168.1.2 is not available
and ARP table shows the following
0 D 192.168.1.2 00:00:00:00:00:00 ether11
I tried to change the position of jumper bypass to “0” or “1”. It did not help. But if you connect to 1-10,13 port is operating normally.
You can tell where to find the answer please?
