Bypass speed isp via VPN Mikrotik?
Anyone know how to increase ISP speed using the Mikrotik VPN, when we connect to the Mikrotik VPN then our ISP was only 10Mbps up to 30Mbps only via VPN?
If I understand correctly, you have a MikroTik VPN somewhere and you’re connecting to it through some ISP. Then you can’t increase your speed, as all of your traffic has to go through your ISP’s network before reaching your VPN.
Maybe you are reffering to ISP throttling? it is when your provider limits your speed when youre consuming too much bandwidth. I guess to answer the question it is better if you state your package/plan
Can you use a VPN to go faster than your current internet speed?
Is that what you asked?
If so, in short… No.
